Subject: Question about the favicon
btriyono
14 Feb 2008 11:46 AM
What do I need to do in order to change the favicon? Do I have to change anything in my default.aspx or web.config or can I just delete the favicon.ico in the root folder and change it with a new favicon?
Thank you so much for the help.
14 Feb 2008 6:13 PM
You should actually put the favicon in the root directory for the site. What you put in Portals/_default will be the default favicon for any site that doesn't have one. Put the favicon for site 0 in Portals/0, etc.
And, while you are at it, you can get rid of the favicon file in the root web directory.
Roshdy25
26 Feb 2008 7:25 AM
the portal must refresh when browse with firefox
how to solve this problem
i use ajax in all behavior in the site
26 Feb 2008 6:55 PM
The favicon is stored in the user browser's cache. Clearing the cache on the browser will fix it.
Forums > Skinning Toolkit > Skinning Toolkit > Question about the favicon
RE: Database error by derpir
Hello thanks for the tip Lee but I can't find were to change the Authentication mode on my SQL Serv...
have a look here
