Subject: IE7 and DNN 4.6.2
espdenver
13 Nov 2007 7:47 AM
I had a question for you regarding a full css based skin that was delivered to us from a company out of the UK. We have it working really well in all browsers except for IE The dev site is http://mad2.sci-isp.com As you can see in IE, vs Firefox - the grey box on the homepage (lower right is broken and the top navigation behaves odd and there is a slight alignment issue. We are experienced skinners and we're not sure why this is occuring. Any thoughts?
13 Nov 2007 4:45 PM
I can't see a grey box in the lower right, but I can see in the menu in IE7 that it slightly pops out on the lhs - I'm guessing due to the box model differences.
In the FreeStyle skin you can look at the code and in there is an iehacks.css file which is setup to individually target IE6 + 7 - you can also specify details just for IE5. - Using this file you need to bear in mind that ALL IE browsers will read this file.
- So using this you may be able to fix some of the dimensions problems that you are having specially for IE7
Hope this helps,
Forums > Skinning Toolkit > Skinning Toolkit > IE7 and DNN 4.6.2
RE: Pop up window by jncraig
Pop up window by yerann
