Subject: Replacing Skin
design4dotcom
28 Sep 2007 9:30 AM
I'm using DNN 4.5.5.
I want to replace the default skins with something more customized.
My question is will I lose my content on the website?  I have many pages already set up.
I'm doing an FTP back up of all my files right now.
Thank you for your help.
Michelle
Michelle Dettlaff
Design 4 Dot Com, Inc.
407-210-3600 x 1
Professional Website Design
28 Sep 2007 10:35 AM
Welcome to the forum. - You will not lose any pages if you change your skin.  The content of your pages is stored in the database. For information on how DotNetNuke works check out:
An Introduction to the Principles of DotNetNuke
When you create a backup make sure you backup your database as well.
You may want to check out:
The beginners section on the tutorials page is a good place to start.
Hope this helps,
Login page by shanny234
---resolved---
03.04.00 Thanks Bryan
