Subject: content template
aliboni
30 Jul 2007 12:00 PM
hi
the fck editor has some usefull template to add content to a container...
is it possible to create your own template?
is there a tutorial for this?
thx
30 Jul 2007 12:12 PM
Try:
I know that one of these shows how to install custom styles in the FCKEditor.  If I had to guess, I'd say it was the last one, but I'd recommend viewing all three in order.
aliboni
30 Jul 2007 12:41 PM
i saw the first 2 tutorial u mention, and i know now how to create new styles...
but my question was about the template...
for example using the first template i have a blank formatted content like:
img(blank)              type text (formatted with size and bold)
                               type text (normal text)
and then simply cliking on the blank image i upload the image i want and typing over "type text" i can add my title and content with the styles already choosen, so i don't have to copy the text and choose the different styles for each paragraf...
i think that this template is a great resources, it is very quick and simple to add the content... but only if i can create my own template!!
so i'm viewing the tutorials in the site, but still didn't find this....
13 Aug 2007 10:26 AM
aliboni, just to let you know, I am currently recording some videos for page templates for the next issue. This should help solve your problems, thanks,
Lee
Geni
23 Apr 2008 5:15 PM
Hi i was just looking for this, i think he is talking about the content templates that come with FCK - there is an XML file under Providers/HtmlEditorProviders/FCKeditor/fcktemplates.xml
You need to provide your custom html inside the CDATA areas
Hope this helps albeit a year or so later - ill post how i got on and any gothas - Lee you may have covered this in a tutorial but if not ill post the method i used
Geni
23 Apr 2008 5:49 PM
Success - you can even drop custom styles in this template and it will pick them up - nice! means i can now provide clients with custom templates that mean mistake free content no more layout issues.
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
