Subject: adding contentpane after skin is uploaded
basg
27 Mar 2007 10:09 AM
I have this skin and it works great but now I want to add another contentpane where I can put modules into. Is this possible?
I tried changing the source of the .ascx file and put in:
but it doesn't show up in the panes dropdownlist. Do I have to upload the skin again or can dotnetnuke render it again or is this even possible? Is there some literature where I can read what happens if a skin is uploaded.
regards Bas.
basg
28 Mar 2007 9:07 AM
I tried changing the source of the .ascx file and put in: [div id="newpane" runat="server" class="newpane"]
10 Apr 2007 5:49 AM
Did you get this to work, the code looks correct.  You may also want to add to your code visible = "false" - this means that the new content pane will not be displayed if the module is not inserted into the content pane.
If DotNetNuke sometimes does not pick up your new changes you may need to refresh the page (press control and F5).
Forums > Skinning Toolkit > Skinning Toolkit > adding contentpane after skin is uploaded
