Subject: [breadcrumb] customizing
Bahy
12 Jan 2010 12:58 AM
How can I do this with DNN, since I want the last (the current page) is not a link, and have other style format? This token has only 3 attributes and I don't know if this is possible to do the customizing for this token.
17 Jan 2010 3:02 PM
It is possible to modify the breadcrumb skin object. Look for information in Tom Kraak's blog at seablick.com and Mitchel Sellers' blog at mitchelsellers.com.
Forums > Skinning Toolkit > Skinning Toolkit > [breadcrumb] customizing
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
DNN Creative Subscribe
