Subject: Please help with CSS container
DrakenKorin
09 Jul 2008 4:39 AM
I have a slight problem with my css container.  I have a simple module for uploading and displaying profile pictures.  when I upload an image, the container doesn't expand to surround the image, instead the image spills over the edges of the container.
I've added a small screen shot so that you can see what I mean.
Some background info:  I created the skin and containers using the CSS tutorial found on this site, so that means that the left and center columns are floated, I don't know if that could be the reason?  (since the photo module is in the left column)  I moved the container to the right column, which is not foloated, but to no avail.
Any assistance would be greatly appreciated.
Regards
Julian
DrakenKorin
10 Jul 2008 3:52 AM
pls. anyone?
10 Jul 2008 7:39 AM
Could you perhaps attach your container file to a message and also include the CSS that styles it?
DrakenKorin
10 Jul 2008 8:27 AM
Sure, here are the contents of my css and container files
css:
.cssLightcontainerHolder_transparentBox
    border: solid 1px #8EB4E3;
    background-color: #CCC;
    margin-bottom:10px;
.cssLightActions_image
    background-color: #8EB4E3;
    border-bottom: solid 1px #8EB4E3;
    padding: 2px 5px;
.cssLightContainer_image
    padding: 6px 5px 0px 5px;
Container XML:
        [ACTIONBUTTON:1]
                CommandName
                AddContent.Action
                DisplayIcon
                True
                DisplayLink
                True
        [ACTIONBUTTON:2]
                CommandName
                SyndicateModule.Action
                DisplayIcon
                True
                DisplayLink
                False
        [ACTIONBUTTON:3]
                CommandName
                PrintModule.Action
                DisplayIcon
                True
                DisplayLink
                False
        [ACTIONBUTTON:4]
                CommandName
                ModuleSettings.Action
                DisplayIcon
                True
                DisplayLink
                False
        [ACTIONBUTTON:5]
                CommandName
                ModuleHelp.Action
                DisplayIcon
                True
                DisplayLink
                False
        [ACTIONS]
                ProviderName
                DNNMenuNavigationProvider
                ExpandDepth
                1
                PopulateNodesFromClient
                True
I hope this helps
10 Jul 2008 2:03 PM
You can attach zip files to your forum posts, could you attach the entire container and skin?
I need to see the actual container html.
There maybe a float on the image that needs clearing, you may need to add a < br class="clear" / > at the end of your container html?
DrakenKorin
14 Jul 2008 7:22 AM
Sorry for taking so long to get back, I see your forum's "alert" functionality is similar to mine, in the sence that it only works half the time, LoL
Here are my complete skin and container zip files
In the mean time I'll try the < br class="clear" / >  When I read it a little voice in my head went "Doh!"  I'm sure that's the problem, I will let you know if it is.
Thanks in advance
Attachment: 1714225157371.zip
Attachment: 1714225171454.zip
DrakenKorin
15 Jul 2008 2:02 AM
Well, i tried entering < br class="clear" / > to the end of my container, but I'm either not doing it right, or that isn't the problem ??  Maybe I'm placing it in the wrong place, but then again, how many places could there be? lol
Please help,
Regards
Julian
15 Jul 2008 7:47 AM
well, I have added the skin and container to a test area and added a text HTML module to the left pane with an image inside the module.
This does not have the problem with the container  around the image, this leads me to think that it must be some sort of problem with the photo upload module.
Are there any floats set in this module?  Is there any CSS applied to images in this module?
I have attached a version with a clear class which you could try, I added it to the container and added the clear class into the skin.css file.
Attachment: 171547781471.zip
DrakenKorin
16 Jul 2008 6:08 AM
Hi Lee,
Thanks for all your efforts, it is much appreciated.
The problem does not occur with the test skin that you supplied, so I just adapted my skin by cutting a pasting snippets of your code, all's working fine now
I must adimt I'm still a bit stumped in the sence that I fixed the problem, but could not really find the cause in the first place.......I'm propably looking into the back of my eyelids and not spotting the obvious, as such things go lol
Thanks again!  (I often wonder how much of DNN's success is due to this website???)
Regards
Julian
17 Jul 2008 11:14 AM
lol - no problem, glad to help,
Cheers,
Forums > Skinning Toolkit > Skinning Toolkit > Please help with CSS container
RE: Pop up window by jncraig
Pop up window by yerann
