Subject: Vertical Solpartmenu
navvin_20
08 Jul 2008 11:24 AM
Hi Lee,
I need ur help with the vertical solpartmenu. The vertical solpartmenu is supposed to show all the pages in the menu..and no problem abt that its working fine.
But the problem is the gap between the menu items is too  much meaning to say for instance the gap between Admin and Host or Home page and the very next item in the menu is very large.
I am not able to reduce the gap between them...I have gone thru the skin.xml and skin.css file completely. But to my wonder I didn't get any clue.
I really need ur help.
Thanks in Advance,
Navvin
10 Jul 2008 1:54 PM
do you have any URL we can look at?
 or could you zip and attach all of your skin files to this forum post?
navvin_20
10 Jul 2008 2:20 PM
Hi Lee,
Thanks a lot for your reply.
I forgot to mention in the forum that I got solution to my problem.
Actually it was resolved by removing the
from the Separator setting of solpart menu.
Anywayz thanx for replying back!!!
--Navvin
Forums > Skinning Toolkit > Skinning Toolkit > Vertical Solpartmenu
Login page by shanny234
---resolved---
03.04.00 Thanks Bryan
