Subject: adding javascript to skin
dbayerdorffer
03 Jun 2008 3:50 PM
Hi Everyone,
I'm having a real issue trying to add a short javascript to the end of our skin file. When the pages on our website get rendered the javascript I added is gone.
I need to have the javascript appear just before the tag.
Does anyone have any experience with this?
Daniel
05 Jun 2008 3:04 AM
It maybe worth looking at the Simple Red Leaf skin, this skin has a piece of Javascript inside the skin code, thanks,
dbayerdorffer
05 Jun 2008 10:10 AM
Hi Lee,
Thanks for sending me the link. I'm looking at it now. I've also solved my problem. The issue was I had to make my DNN site re-process the skins. It then used the changed version. I was trying to upload a new skin with the same name as the old one. DNN did not like it!
Daniel
Keane
05 Aug 2008 3:30 PM
how to add javascript to my Skins ?
07 Aug 2008 1:58 PM
See the tutorial to which Lee referred.
Forums > Skinning Toolkit > Skinning Toolkit > adding javascript to skin
RE: Pop up window by jncraig
Pop up window by yerann
