Subject: Radio Button List & Checkbox Font Size
soupy6667
02 Jun 2008 5:53 PM
Hi Lee,
I have used H2O from www.onyaktech.com to design a Student Enrolment Form.
http://www.intertag.com.au/StudentEnrolmentForm/tabid/95/Default.aspx
The thing is that I want to change the font size of the Radio Button Lists and Checkboxes. Chris from onyaktech has informed me that I need to update the skin.css file.
Do you have any ideas of where in the skin.css I need to be looking?
I can't find any info anywhere and I'm beginning to become frustrated.
Thanks.
Andrew
02 Jun 2008 7:24 PM
You'll probably want to review these tutorials:
What you need to do is find the classes for IDs that style the objects of interest.  You can do this with the Web Developer's Toolbar that is demonstrated in the "Troubleshooting" tutorial.  Then you'll need to open up the skin file and either change or insert the styles that you need to change.
If that's not enough of a pointer, ask again.
soupy6667
07 Jun 2008 5:07 AM
Hi Joe,
OK. I've spent about 4 hours and I am having no luck at all. It is becoming very frustrating.
I have reviewed the tutorials as you suggested and they helped to a degree except I cannot find how to adjust the font size for the radio buttons and check boxes.
Can you point me in the right direction.
Thanks.
Andrew
07 Jun 2008 8:43 AM
Have you identified the IDs that go with those items?
soupy6667
I get this:
08 Jun 2008 5:38 PM
Hi Joe,
Using FireFox and the developer toolbar as described in the video I have looked at the 'ID & Class Details'.
1. Employment Details
Which of the following categories best describes your current employment status?
Select One
#dnn_ctr526_H2O_ctl00_h2oCell_23_0
#dnn_ctr526_H2O_ctl00_h2oCell_23_1
#dnn_ctr526_H2O_ctl00_EmployDetails
#dnn_ctr526_H2O_ctl00_EmployDetails_0
#dnn_ctr526_H2O_ctl00_EmployDetails_1
#dnn_ctr526_H2O_ctl00_EmployDetails_2
#dnn_ctr526_H2O_ctl00_EmployDetails_3
#dnn_ctr526_H2O_ctl00_EmployDetails_4
#dnn_ctr526_H2O_ctl00_EmployDetails_5
#dnn_ctr526_H2O_ctl00_EmployDetails_6
#dnn_ctr526_H2O_ctl00_ctl800
#dnn_ctr526_H2O_ctl00_h2oCell_24_0
At the top of my H2O form there is this:
 #dnn_ctr526_H2O_ctl00_lblError #Tabledf .Normal
#Tableform .Normal .Normal
#dnn_ctr526_H2O_ctl00_pnlForm
#dnn_ctr526_H2O_ctl00_pnlControls
#dnn_ctr526_H2O_ctl00_h2oCell_0_0
I guess that the CSS is therefore from the .Normal class?
Is there a class for Radio Button Lists and Checkboxes?
I have tried chaning the CSS using 'Edit CSS'. Everything I have changed has had no affect at all on the font.
Regards,
Andrew
09 Jun 2008 2:58 AM
You have a couple of options:
First is to specify a font size for all table cells - but bear in mind it will affect all table cells where this skin is used, so you will need to just apply it to this skin on this page
td {
font-size: 20px;
Or, you could identify the ID for each table section and specify a font for each of those, but this will involve code for each separate table that is used for each question.
font-size: 30px;
Forums > Skinning Toolkit > Skinning Toolkit > Radio Button List & Checkbox Font Size
RE: Pop up window by jncraig
Pop up window by yerann
