Subject: The video tutorials are Superb!
maxr
09 May 2006 10:08 AM
After spending lots of time in understanding DotNetNuke I found DNN Creative website.
Last year I signed up for membership (after looking at more than a dozen other websites) at DNN Creative. I'm too busy working so reading for many hours is something I don't have time for.
The video tutorials and explanation saved me so much time in understanding DotNetNuke. After visiting many websites explaining DotNetNuke DNN Creative really stands out by providing in-depth and up to date information.
The video tutorials explain DotNetNuke in a easy to understand manner not overseeing the important details. The tutorials revealed many "secrets" I did not know before what makes it all a lot easier to understand.
If you are a beginner or advanced user of DotNetNuke, DNN Creative tutorials is your source of information. Yearly membership fee is only $39.00 and is worth every penny of it. If you are serious in understanding DotNetNuke to the Max DNN Creative is the source you have been looking for.
Continue the good work!
Max Roosenbrand (Website & Software Developer for Techlion, The Netherlands)
Forums > Users Lounge > Testimonials > The video tutorials are Superb!
Member log in by HUGHD37IUOE
Video Problem by icdlbake
