Subject: Creative DNN Rocks!!!
Juan Colome
09 May 2006 7:22 AM
I've had the pleasure of being one of Lee's subscribers for over 6 months now and I can say without a doubt that his work is amazing.  The learning curve to learn DNN is minimized drastically once you learn from his videos.  Lee, keep up the great work and I always look forward to your next release :-)
Top notch presentations and training.
With confidence,
Juan Manuel Colome, Founder
Infoseek Technologies, Inc.
www.LocalMiamiGuide.com
www.InfoseekTechnologies.com
Forums > Users Lounge > Testimonials > Creative DNN Rocks!!!
PayFlow Link by murphydolores
RE: Send email with Dynamic Forms Results by jesp17
Hi Lee,I've asked DataSprings if there is a way to solve my problem (wish). Here is a reaction:I don...
Background Music by kparker
Do you know of any module that I can use to play background music on a single page?  Or do you have ...
I did this several years ago, so I think that what I found must have been in the "Professional DotNe...
