Subject: DNN Creative, is one for the DNN Beginner...!!!
soupy6667
09 May 2006 4:08 AM
DNN Creative ROCKS!
2 weeks ago I learnt about DotNetNuke. Early last week I was quoted $4,500.00 (AUD) for someone to design my DNN Portal Skin and supposedly back end.
So, I did what we all do. Turned to Google and ran a search, and thats how I found DNN Creative.
I invested apporx $50.00 (AUD) to become a subscriber and not only can I download a heap of tutorials to view off line but get help when I have asked for it. Wow! This is truely the best investment I have made for a long time....
I'm an ABSOLUTE BEGINNER with DNN and DNN Creative has helped me do the following:
  • Install IIS on Windows XP Pro
  • Install DNN 4
  • Install Microsoft Visual Web Developer Express and SQL Server 2005 Express
  • Install the FCKEditor
  • Design my first skin (I won't share as it is quite crude, yet a start)
  • Understand CSS Skins
Lee has been a tremendous help and I appreciate all of the assistance he gave me to get it all setup.
Thanks, Mate!
Andrew Campbell (soupy@ihug.com.au)
Forums > Users Lounge > Testimonials > DNN Creative, is one for the DNN Beginner...!!!
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
