Subject: Great Value
Alan Budyta
13 Jan 2007 6:22 AM
Lee:
I just want you to know what a great site you have put together to help learn DNN.  I have received tremendous value from your training videos.  Your newsletters hit right at the topics I am interested in learning more about.  Bottom line:  Your subscription worth every penny and more.
I would recommend your site to anyone who has an interest in DNN.
Keep up the good work.  I wish you continued success at DNN Creative.
Alan Budyta
www.electronic-payment-services.com
Forums > Users Lounge > Testimonials > Great Value
I did this several years ago, so I think that what I found must have been in the "Professional DotNe...
RE: Server Error in '/' Application. by michellb
Here is the entire text on the page: Server Error in '/' Application. Runtime Error Descrip...
