Subject: Makes DNN easy for NON programers
markp
13 Dec 2006 3:21 PM
These tutorials have made it easy for me to learn how to install, setup and  skin (nothing fancy yet), DNN.  I have installed the editor recomended by Lee , which intails changeing the web.config file, the tutorials made it a breeze.
You keep making them , I will keep watching!
Thanks Lee
Forums > Users Lounge > Testimonials > Makes DNN easy for NON programers
Glad it's working!
Firefox SWF file by ce221
PayFlow Link by murphydolores
DNN Creative Subscribe
