Subject: These tutorials really make a difference!!
Tom Conant
12 Dec 2006 8:14 AM
I can not thank you enough for the wonderful work you are doing in helping us "non-programming" types to better understand and become more comfortable with DNN. What I think is especially important and valuable are your tutorials on some of the modules. For example the one you did for WildPortfolio was a godsend. Not being a programmer and not familiar with the basic ins and outs of html, etc. it always seems pretty easy on the surface but I find when you get into the thick of things and run into problems it certainly can be frustrating. Personally I never have cared much for user manuals. For me, watching and learning from tutorials like yours definitely makes a  big difference. I can honestly say that if it wasn't for your videos I probably would not have made the decision to invest the time and learn how to work with DNN
Forums > Users Lounge > Testimonials > These tutorials really make a difference!!
RE: How to Create an Email Form with OWS - Issue 49 by CelesteT
Hi, Was also wondering if there was a way to incorporate ReCaptcha (www.recaptcha.net) into the emai...
Hi, Thanks for the great tutorial. I was wondering how I can hard code a "to" email address into th...
That will work.
