Subject: Kudo's
Len
15 Jul 2008 2:20 PM
Lee, your presentation, demonstration and attention to detail is incredible. Thank you for taking the time to teach me all I need to know about skinning. I can't wait to use this knowledge and look forward to the rest of your tutorials!
-Len Q.
DPS Technical Service
Flint, MI
That will work.
