Subject: My DNN site for Review
SupaHoopsa
12 Mar 2009 6:25 AM
I would be grateful for any feedback on my FIRST live DNN site:
Fleet Town Colts
Please be gentle with me fella's
12 Mar 2009 9:24 AM
I didn't dig through the site, but the home pages has a nice visual impact.
When I first went to the site, it timed out. Then it came up when I reloaded the page. You might want to look at "keep alive" services to keep your site alive.
SupaHoopsa
12 Mar 2009 10:16 AM
That's good to know.
The site is being hosted by PowerDNN and according to a recent post on the DNN forum all accounts/domains on their shared hosting option should be getting there keep alive service.
I logged a call with them only this morning about this, so I can now use this thread as further evidence that it is not working on my site.
Aside from this issue, what did you make of the site once you got in?
Terry Sadler
12 Mar 2009 7:44 PM
Not bad..I thought it was nicely done. No problems with the page loads..you might want to look at changing the favicon to a custom one.
Terry Sadler, CISSP
Compass North Group, LLC
Any man who may be asked in this century, what he did to make his life Worthwhile, can respond with a good deal of Pride and Satisfaction, "I served in the United States Navy". JFK
SupaHoopsa
13 Mar 2009 3:58 AM
Thansk for the idea about the Favicon.
However I have just uploaded a new favicon.ico and I cannot get it to display - i just get the standard DNN icon.
I have tried clearing my browsers cache and I have also restarted my portal, but I still get the standard DNN icon.
When I open this page in Firefox and start firebug I notice the following line in the page header:
This seems to be pointing to the 0 portal???
I don't see this link in my page - is this something you have to code yourself?
Any advice on changing this favicon would be really gratefully received.
Rich.
13 Mar 2009 12:01 PM
Put your favicon in the Portals/N directory, where N is the number of your portal.
If you aren't seeing the favicon, it may be cached in your browser's cache.  Try clearing the browser's cache.
Forums > Users Lounge > Site Review Please! > My DNN site for Review
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
