Subject: Google Maps Tutorial Website
KMOwen
04 Aug 2008 5:24 PM
Please take the time to review this new DotNetNuke website and provide some feedback.
Google Maps Tutorials
Site Design Information: -
DNN 4.8.4
HouseMenu 2
CSS Layout (Using Absolute Positioning)
Uses
   -   Mandeeps CSS Tabs Module on the tutorial pages
   -   Ventrian Child Links on Free Tutorials index page
   -   Google Custom (Adsense) Search
   -   Google Adsense
Feedback most welcome.
mgordon
19 Aug 2008 12:55 PM
I took a look at your site.  It was not bad at all.
My only suggestion would be to somehow delineate what is an ad versus content (left side of page versus right side), but only if you're not too dependent on the revenue from the clicks.
Graphics would be helpful for design purposes,  but I say that because I'm into User Interface and people warm up to a site that has some good photo's.
Your site loaded up very fast.
Good job!
Mark Gordon
Webmonkey
Forums > Users Lounge > Site Review Please! > Google Maps Tutorial Website
