Subject: Setting up the RSS News Feed XSL Stylesheet
Sh@wn
26 Mar 2008 4:25 PM
Hi everyone,
I have two problem in the RSS_MainTitle_Images_Date_Formatted.xsl file that I download in:
http://www.dnncreative.com/Portals/0/tutorials/RSS/RSS_MainTitle_Images_Date_Formatted.zip
1) I'd like that every links open a new page (target="_blank");
2) Where I put this string for limiting the number of News Items displayed?
Any help is appreciated.
Thanks.
Marco
Www.Informatori.Info
27 Mar 2008 7:17 AM
1) is explained in Setting up the RSS News Feed XSL Stylesheet
so, for example in that stylesheet look at this line of code:
(NOTE: in these examples I have added spaces before and after the < and > so that they display in the forum)
 < a href="{$ilink}" title="{$idesc}">< /a >
and add in
 < a href="{$ilink}" target="_new" title="{$idesc}">< /a >
2) I have not tested this code, but from looking at the date xsl file and the limit number of xsl file:
This is the code to limit number of items to 5
 < xsl:if test="position() < 6" >
    < br >< /br >
    < !-- to open links in a new window, change target="_main" to target="_new" -- >
    < strong >< a href="{link}" target="_main" >< xsl:value-of select="title"/ >< /a >< /strong >
    < br >
        < xsl:value-of select="pubDate"/ >
    < /br >
    < !-- only display markup for description if it's present -- >
    < !-- < xsl:value-of disable-output-escaping="yes" select="description"/ > -- >
    < br >< /br >
  < /xsl:if >
combining it with the date formatted.xsl I would try:
< div class="head" >
 < xsl:if test="$image" >
    < a href="{$ilink}" title="{$idesc}" >< xsl:value-of select="ilink" / >< /a >
    < img src="{$image}" height="{$ihigh}" width="{$iwide}" style="float: left; margin: 2px; border: 0px;"/ >
 < /xsl:if >
 < font size="-2" >< xsl:value-of select="description"/ >< br/ >
     < a href="{$link}" >< xsl:value-of select="title" / >< /a >< br/ >
 < xsl:value-of select="webMaster"/ >< br/ >
 < xsl:value-of select="copyright"/ >< /font >
 < hr/ >
< /xsl:if>
< /div >
Forums > Users Lounge > Everything Else > Setting up the RSS News Feed XSL Stylesheet
