Subject: Seting Up Virtual PC on Windows Vista Business
soupy6667
19 Jan 2008 6:21 PM
Hi Lee,
I have just downloaded and installed Virtual PC 2007 and installed it on my Windows Vista Business Laptop. I thought this was a brilliant idea. I saw you using it in one of your tutorials from issue 20, I think.
Anyway, the installation went through without a problem and I was able to install Windows XP Pro. I am having a problem getting this installation of VPC to connect to the internet.
Do you know of any thing I need to do to allow me to connect to the internet through my Vista machine?
Thanks.
Regards,
Andrew Campbell
soupy6667
19 Jan 2008 6:35 PM
Hi Lee,
Don't worry I worked it out. I had to change settings for the Network Adaptor to Shared Networking (NAT).
It is now working.
Cheers,
Andrew
22 Jan 2008 6:02 AM
ok glad you work it out, have fun!
Cheers,
Forums > Users Lounge > Everything Else > Seting Up Virtual PC on Windows Vista Business
