Subject: No Working Action Buttons on Modules
dogalpha
18 Jan 2008 11:30 AM
I installed Ver 4.7 on 2 of my GoDadddy sites for testing and perhaps implementation.
When I hover over the Down Arrow for the Actions Menu on a module it just sits there and spins.
There is a tablet icon which shows up but I don't think it gives the same options.
Am I missing a Plugin perhaps.
I tried accessing in FireFox and IE with the same results.
Any help would be appreciated.
greenflash
18 Jan 2008 3:28 PM
Hi dogalpa; go to Godaddy File Manager and check out permissions, a visitor of my blog had this problem as well, it looks like Godaddy does not apply ajax on express packages.
DotNetNuke Help for beginners
18 Jan 2008 3:29 PM
I think that this is an AJAX issue, too.
Forums > Users Lounge > Everything Else > No Working Action Buttons on Modules
