Subject: Need help with xml playlist
mattfarmer
30 Dec 2007 8:19 AM
I have been trying to create an xml playlist for a .flv module that does support xml playlists.
I have never tried to creat one before but after looking on the web i think i had the idea, but i can not get it to work.
I have pasted the file below (i am just trying to get one .flv file playing) and was wondering if someone maybe able to point out any obvious mistakes.
The hosted domain is nutonikmusicproduction.com but the website that i am trying to put this on is refered to as portal 7.
Many thanks,
Matt.
- <playlist version="1" xmlns="http://xspf.org/ns/0/">
- <trackList>
- <track>
  <title>Tutorial 1 - Welcome and introduction.title>
 <location>http://nutonikmusicproduction.com/wwwroot/Portals/7/Tutorial1/Tutorial1.flvlocation>
  track>
  trackList>
  playlist>
Forums > Users Lounge > Everything Else > Need help with xml playlist
