Subject: Scheduled procedures and upgrading
DLSTaylor
28 Dec 2007 4:54 AM
Should the scheduled procedures be stopped before running an Upgrade of DNN?
28 Dec 2007 1:41 PM
No, you don't need to do this explicitly.
Mitchell Sellers has a pretty good description of DotNetNuke upgrade procedures here.
Forums > Users Lounge > Everything Else > Scheduled procedures and upgrading
