Subject: Best way to take payment and give instant access to designated site areas
drwnjulia
11 Dec 2007 8:15 AM
Hi, Iv'e posted this question in the module area but have not gotten any answers, so I posted it here.
I need to accept payment on the site i'm creating. Once payment is made, I want the paying customer to have instant access to designated areas on the site without a person having to manually giving them access.
(KIND OF LIKE THE DNNCREATIVE SITE IN WHICH you creat a user ID & password, and ONce you pay you can post in the forum)
How would I go about doing this??
any Help would be appreciated.
Drwn
11 Dec 2007 8:35 AM
If you want to set up a subscription system like DNN Creative we use ventrians subscription tools
Lee
Chris@ICSIT
14 Jan 2008 10:59 PM
Hi drwnjulia,
I have written custom modules to do exatly this with paypal.
Let me know if you still need help with it.
Regards
Chris
www.ICSIT.com.au
www.icsit.com.au
Forums > Users Lounge > Everything Else > Best way to take payment and give instant access to designated site areas
