Subject: Opening Visio Diagrams Issue
MikeW
29 Oct 2007 12:19 PM
I'm using DNN on my company Intranet for a documentation portal. I have various types of documents that I'm linking to via the Documents portal.  I don't have any problems linking to Word or Excel files and opening them.
However, if I link to a Visio diagram, when I try to open it I get the Windows Login dialog, and am prompted for a username/password.  If I click the Cancel button a few times I can evenutally load the Visio diagram.
Does anyone know why this happens and/or how to prevent it? I need to be able to open a Visio diagram just like any other document.
Forums > Users Lounge > Everything Else > Opening Visio Diagrams Issue
Still no luck with this feed. I can get both of these links to render if pasted in Internet Explore...
thanks for posting info,
03.04.00 Thanks Bryan
