Subject: Skin Question
22 Oct 2007 4:04 PM
Is it possible to create a skin that has invisible panes?  If so, how would I make the panes invisible?
I have in mind creating some "printer-friendly" skins for my site, and I'd like -- at least for some pages -- to have the left or right pane, and perhaps the headers and footers disappear.
cozahost
29 Oct 2007 2:46 PM
Hi there
Please help me, I have tried everything and still don't know how to create rounded container for windows internet explorer.
Regards Jani
29 Oct 2007 10:31 PM
If you google" DotNetNuke rounded container" you'll find a lot of references. There are references to free skins with containers that have rounded corners. There are also skins for sale for between $10 and $20. It might be worth your while to purchase one and see how it's done.
(This is my long and indirect way of saying that I don't know the answer ... )
30 Oct 2007 2:38 PM
Hi Joe,
If you want to create a print skin, all you need to do is use a print.CSS file - from there you can specify which panes and skin objects you wish to appear on the print page.
For instance you can use the following code to remove these div ids:
#sidebar, #extras, #header p
    display: none;
- You can see examples of this on these skins:
I will also be creating a tutorial for release in the January issue which will outline how to use the print.CSS file.
30 Oct 2007 2:56 PM
Thanks, Lee. This is a lot simpler than the approach that I took, so I'll have to give it a try!
30 Oct 2007 6:51 PM
I took the skin picker code, pasted it into the bottom of my .ascx skin file, copied my module.css to skin.css and editied it. That's it!
A very nice solution, too!
