Subject: Issue 22 Backing up sites......
jinjaninja
03 Oct 2007 3:46 PM
Just tried to backup my DNN site following the guidelines in issue 22. I've backed up the DataBase on the server and downloaded to my local drive. When I go to restore backup I am given an error about an mdf file not being on drive E:/ I don't have a drive E but I have a feeling my server will. I can find the mdf on the server but I cannot place it on an e drive at my end.
Tried MS for help, banging my head against a brick wall there, any other ideas? I can't be the only person in the world who has foudn this error.
Cheers
Si
05 Oct 2007 11:01 AM
Yes, when you are selecting the Database to restore, tick the restore box next to the database and then on the left under 'select a page' click on 'Options' - Here lists the location of where the database will be restored to on your system, you will need to change this drive URL to match the location of your SQL Server installation
Forums > Users Lounge > Everything Else > Issue 22 Backing up sites......
