Subject: How to change the host email address?
Shakani
01 Oct 2007 8:43 PM
Friends, could someone please tell me how to change the host email address in DNN 4.5.0?
Thank you,
Saleem
01 Oct 2007 11:33 PM
You'll find it on the Host Settings page.
There is also an administrator for each portal, and the site administrator's email address is picked up from the Administrator's email address. You set the administrator on the Site Settings page, under one of the advanced settings.
ALEXw
02 Oct 2007 2:02 AM
Hi, when logged in click on host next to logout, in the top right hand corner. This takes you to the host settings page.
02 Oct 2007 7:13 AM
just to make it clearer:
1) There is an e-mail address for the host super user, to edit this log in as the host user and then click on the host user name next to the logout link.
2) In the host menu / host settings there is a host e-mail option - this is related to the e-mail for your entire DotNetNuke installation which is used as a support email for the portals in your installation.
Forums > Users Lounge > Everything Else > How to change the host email address?
