Subject: This might be wrong place to ask this question
4indianwoman
27 Sep 2007 9:12 PM
This might be wrong place to ask this question. One of my friend, hales from Pakistan wants to work in Singapore... How about living there?
Do the placement consultancies can help us in this regard? Which one is the best and popular consultancy there?
Thanks in advance!
Forums > Users Lounge > Everything Else > This might be wrong place to ask this question
