Subject: New page, disappears and then changes order in menu!
mattfarmer
31 Aug 2007 10:43 AM
I am having a problem and i am just wondering if anybody has an idea as to what is going on.
The problem is the following:
I have created a new page and it appears in the menu.
I then log out and as i click on the menu to view the different pages the page that i just created (download page) seems to disapear and change order when i click on certain pages in the menu.
This is very strange and i have never come accross this before, do you have any ideas?
The site is www.six-strings.com (it is under development)
Thankyou
Matt.
01 Sep 2007 6:47 PM
Are you still having a problem? If so, please give me some instructions as to how to reproduce the problems.
Forums > Users Lounge > Everything Else > New page, disappears and then changes order in menu!
