Subject: Removing Blue border around Search Button
jamx551
23 Aug 2007 5:59 PM
Hi All
In my website at http://www.premierwebplatform.com/cornelius/Home/tabid/2280/Default.aspx
you will notice the 'Go' button has a blue border .. I would like to remove that annoying blue border
I ofcourse declared it in my xml.. I tried using border-style:none in the CSS but it doesnt work
Any other ideas?
23 Aug 2007 7:22 PM
It looks as if you've removed the blue border. But, it also appears that you have a white background. I'd have to look at the code, but I think that you want to make the image have a transparent background.
jamx551
23 Aug 2007 8:35 PM
No the blue border is still there.. you need to view it in IE..
Here's the code in XML :
[SEARCH]
submit
CssClass
code in CSS :
.Search {
FONT-SIZE: 10pt; COLOR: #fff; FONT-FAMILY: BerlinSansFBDemi, Tahoma; border-style: none; TEXT-DECORATION: none
A.Search:link {
A.Search:visited {
A.Search:hover {
FONT-SIZE: 10pt; COLOR: #f80000; FONT-FAMILY: BerlinSansFBDemi, Tahoma; border-style: none; TEXT-DECORATION: none
A.Search:active {
Anybody else has an idea?
jamx551
23 Aug 2007 8:36 PM
[SEARCH]
submit
CssClass
jamx551
23 Aug 2007 8:37 PM
Sorry for the missing code above..
here the XML code:
    [SEARCH]
        submit
        CssClass
jamx551
23 Aug 2007 8:39 PM
    [SEARCH]
        submit
        CssClass
jamx551
23 Aug 2007 8:39 PM
submit
jamx551
23 Aug 2007 8:42 PM
Im sorry but I seem to have problems pasting here the XML code.. it doesnt display them right.. anyway part of the code is ]]>
jamx551
23 Aug 2007 8:43 PM
Oh this is really weird.. the code I typed doesnt still display properly..
23 Aug 2007 10:11 PM
No, you have to leave out the tags, or use [ and ]. The text that you type into a forum message is interpreted as HTML.
jamx551
23 Aug 2007 11:38 PM
Object
Token [SEARCH] Token
Settings
Setting
Name submitName
Value ![CDATA[img src="go.jpg"]] Value
Setting
Setting
Name CssClass Name
Value Search Value
Setting
Settings
Object
03 Sep 2007 3:43 AM
It's adding a link border around the image, you could try using in the skin.css:
a img {
border-width: 0;
Which will remove all borders around any images that are links.
Forums > Users Lounge > Everything Else > Removing Blue border around Search Button
