Subject: CSS Skin ActionMenu problem
Graham Stevenson
26 Apr 2006 12:36 PM
Excellent tutorial on CSS skinning :-)). I am trying to implement this and have most of it working on my dnn4.0.2 site.
One issue I have is that when in admin/host mode, pointing at the action menu icon pops up the action popup menu - but its at the top of the page :-((.
I'm probably missing something basic here, so any pointer would be great. Didn't seem to be covered in the video's - just went through them again - unless I missed something again ;-O.
Graham
26 Apr 2006 2:23 PM
Hi Graham,
Glad you have found the tutorials useful.
The problem you are experiencing is due to the Solpart menu. With the CSS skins I installed the HouseMenu which is a CSS menu to replace the Solpart menu.
The information below is listed at the bottom of the skinning tutorial page. These tutorials will provide all of the info you will need.
- One thing which I will be interested to hear about is that I've just checked the housemenu site and it states the menu is for DNN3.x, I haven't tested it in DNN4.x so I will be interested to hear if it works.
If it doesn't there are other CSS menus available which I will find the links for if the HouseMenu doesn't work,
Lee
Initial preparations required in video 1:
Install the HouseMenu
Install the FCKEditor
Links and references mentioned throughout the videos: (recommended to fully understand the tutorial)
Simple Red Leaf CSS Skin
How to install and configure the HouseMenu
How to install the FCKEditor
Browser Quirks and Standard Compliance modes in DotNetNuke (Changing the DOC TYPE, default.aspx file)
How to create re-sizable text in DotNetNuke
26 Apr 2006 2:26 PM
PS. - I've just released today an updated version of the Simple Red Leaf skin, so if you are using it for reference I would download it again.
Just completed the CSS containers tutorials for the next issue to be released on May 1st as well,
Cheers,
Graham Stevenson
26 Apr 2006 3:47 PM
Lee,
Thanks for the response - I'll try the latest code maybe after tomorrow (client demo). I have already done the HouseMenu changes, fckeditor, default.aspx etc., but it looks like the popup action menu's on the containers are still using Solpart :-((.
See sample script below.
I would give you a URL but I can't until I have shown my client tomorrow ;-)). Then I may be able to let you see it - as that would probably help.
Great news on the container tutorial - looks like I'll be viewing that next week ??.
Yes the HouseMenu does indeed work well with dnn4.0.2 :-). I even managed to get the vertical popout menu working, looks great ;-). Main menu is fine - its just the action menu's on the containers....
I'll keep you posted on progress....
Regards
Graham
<script> language="javascript">spm_initMyMenu(null, spm_getById('dnn_ctr415_dnnACTIONS_ctldnnACTIONS'));function onxmlloaddnn_ctr415_dnnACTIONS_ctldnnACTIONS() {return m_oSolpartMenu['dnn_ctr415_dnnACTIONS_ctldnnACTIONS'].onXMLLoad();}</script><script>>dnn.controls.initLabelEdit(dnn.dom.getById('dnn_ctr415_dnnTITLE_lblTitle'));</script><script> language="javascript">spm_initMyMenu(null, spm_getById('dnn_ctr411_dnnACTIONS_ctldnnACTIONS'));function onxmlloaddnn_ctr411_dnnACTIONS_ctldnnACTIONS()
26 Apr 2006 4:47 PM
Hello Graham,
That's good to hear that the HouseMenu works with 4.x - I thought it was the main menu you had problems with, to remove Solpart menu from the containers and replace it with a drop down list, follow this tutorial:
How to remove the Solpart menu from a container
I've just finished uploading the tutorials for CSS, so here you can access the new DotNetNuke CSS containers tutorials
- I may move things around, but I've put the link up so that you can get access straight away if you need the info for your client.
I would be interested to have a look at the code for the vertical pop out menu, I haven't had time to experiment with that yet and would appreciate some info.
The new version of the skin makes the skin completely valid to w3c standards, there were a couple of errors I had made on the containers and I found a way to allow the Javascript to be placed within the main skin for the print.css and iehacks.css files without the W3C finding any errors. - check out: http://skins.dnncreative.com you will see the home page completely validates.
Let me have a link when you are allowed to release it, I will be interested to see what you have created in CSS!
Cheers,
Graham Stevenson
03 May 2006 4:35 AM
Lee,
Many thanks for your help and the tutorials ;-)). these are a great way to get up to speed quickly.
Went through the container stuff - its pretty simple really :-)).
One thing you might want to touch on is the best way to structure multiple skins.containers so that they get installed in a tree - eg company/type/skins (oxns/Transparent/Red etc.) - I don't find it intuitive ;-).
The site is coming along - but is a subscription site, so I'll let you have a login at some point (probably a week or two ;-).
If you send me an email to my private email address (see user table ;-) - I'll send over the skin code so you can see how my vertical menu is built etc. - can't make it public yet :-O.
Having some issues with container transparency between IE6 and FF (now 1.5.0.3), but moving on to content for a while - so this will have to wait....
Thanks again - keep up the good work.....
Regards
Graham
03 May 2006 5:16 AM
Great, glad to hear you got the containers sorted.
I've sent you an email, thanks, will be interesting to have a look at the code - I will make a note of your suggestion in the tutorials list.
Forums > Users Lounge > Everything Else > CSS Skin ActionMenu problem
RE: Google Verification Code Question by BCRose
I found the solution. If anyone else wants to know this information you must go to your home page ...
Where do I place the Google verification code?I have been searching this site but cannot find any re...
Thanks Lee...I have been watching the videos. Lot's to learn here.
Start with:Setup Preparations for SkinningIntroduction to SkinningThen move on to some of the other ...
RE: How to close a website while you are working on it by jncraig
One way would be to assign two URLs -- a public URL and a private URL. Some hosting services provid...
RE: How to do links? by jncraig
There is a links module. If it has not been installed (and many modules are not installed by defaul...
RE: How to install DotNetNuke to Windows 7 - Issue 51 by jncraig
You need to purchase a subscription to DNNCreative Magazine.
RE: How to install DotNetNuke to Windows 7 - Issue 51 by jeihouni
hi,how can i download this video?is it free or i should pay for that?
RE: Enhancing the OWS Login Module and Building a Twitter Module - Issue 54 by bizcomit
How can I change the module/config to log-in using Enter Key ?
RE: DataSprings / Aweber by leesykes
Hello,When I created the tutorial for Aweber, the code they provided was placed within Form tags. An...
How to do links? by Guy..L
How to close a website while you are working on it by mcmanta
The LOGIN and REGISTER links are Skin Objects that are included in your skin file. The easiest way ...
I would like to remove the 'LOGIN' text from the top right of my pages.   How can I do this?   I tri...
