Subject: adding icons to nousemenu
Turoc
22 Aug 2007 8:10 AM
Hi Lee
Is it possible to add icons to housemenu nav items ?
Tx
22 Aug 2007 9:45 AM
Yes it is possible, if you have a look at the read me file that comes with the house menu zip file, you will see there is the option for:
ShowPageIcons
If you add this to your skin.xml file and set the property to true it will display the icons for each page.
- I haven't used page icons before in the house menu but this should be enough for you to get started and work it out.
Forums > Users Lounge > Everything Else > adding icons to nousemenu
