Subject: Any good 'store' modules
mattfarmer
22 Aug 2007 6:41 AM
I am looking for a 'store' kind of module as i am looking to sell .pdf files from my site.
I only need a very basic module as i am simply selling a few .pdf files and i want the user to be able to buy them through paypal.
I had a look at the store module from DNN, but it looks a bit to in depth, and i've heard it has a few bugs.
Anybody have any suggestions please?
Thank you,
Matt.
22 Aug 2007 9:49 AM
Yes I've heard the core store module has a few bugs so I would currently avoid it for a live production website.
The popular store is Catalook - but it's probably too complex for what you need.
There has also been a link posted here where these guys are running a public beta of a store: http://demo.alicommerce.com/
Peter72
07 Sep 2007 6:37 AM
Doesn't Paypal offer its own cart?
Forums > Users Lounge > Everything Else > Any good 'store' modules
