| Author |
Messages |
Marcusw
 Nuke Ace Posts:59
| 17 Jul 2007 4:48 PM |
Can anyone tell me how to add a vertical scroll bar in the content pane of my skin. I suspect I need to creat a new CSS class element to do it but can't figure out the correct syntax?
If I could see any examples that'd also be great.
Marcus. |
 Nuke Master II Posts:2034
| 17 Jul 2007 5:33 PM |
The scroll bar would actually be attached to a module that lives in the content pane, or any other pane.
But, I think that most modules are set to expand vertically to the space that they need.
But, the real question is why do you want a scroll bar, and what do you want it to scroll? If you'll give us some idea of what you are trying to accomplish, that would help. |
Marcusw
 Nuke Ace Posts:59
| 18 Jul 2007 2:11 AM |
I need to be able to set my content pane to a fixed height (say 500px). Then when a Text/HTML module (for example) is placed inside it a vertical scroll bar appears inside the content pane (when the content is higher than 500px). Rather than the whole screen scrolling up and down.
I'm sure I've seen DNN sites that do this.
Cheers,
Marcus. |
| 18 Jul 2007 3:11 AM |
I use this CSS for displaying code on the site:
.codebox { font-family: 'courier new',courier,monospace; color: #000; background:#E0E0E0; border: 1px dotted #999; padding: 10px; margin: 10px; overflow: auto; }
If the code is wider than the display pane a horizontal scroll bar is automatically displayed, if you try this: .codebox
color: #000;
background:#E0E0E0;
padding: 10px;
margin: 10px;
overflow: auto; height: 100px;
when the height exceeds 100px a vertical scroll bar will be displayed
In your text / html module use:
( [] used instead of < > so that is displays in the forum
[div class="codebox"]the test text etc.[/div]
Lee Sykes Site Administrator Subscribe to the website : DotNetNuke Video Tutorials : The Skinning Toolkit : DotNetNuke Podcasts |
Marcusw
 Nuke Ace Posts:59
| 18 Jul 2007 4:13 AM |
Thanks Lee!
I've managed to get that working inside my Text/HTML module but can't seem to get the syntax right in my skin. Here it is (ascx)....
[tr] [td rowspan="3" colspan="3" valign="top" bgcolor="#ffffff" id="contentPane" runat="server"][p][/p][/td] [td colspan="2" valign="top" bgcolor="#ffffff" class="menubackground"][p][/p][/td] [td][img src="[%= SkinPath %]spacer.gif" width="1" height="1" border="0" alt=""][/td] [/tr]
It's tricky putting the div in here without chnaging the layout of the table.
Cheers,
Marcus
aggiedan97
 Nuke Active Member Posts:23
| 30 Jun 2008 9:52 PM |
I am also in need of this exact functionality. However, I have attempted the above with no success. [dnn ver. 4.7.01, IIS v.5.1] 10 paragraphs of lorem ipsum text
(css snippet) .codebox { font-family: Verdana, Tahoma, Arial, Helvetica; color: #000; background:#E0E0E0; border: 1px dotted #999; padding: 10px; margin: 10px; overflow: auto; height: 50px; }
(html skin snippet) <table cellpadding="3" cellspacing="0" width="60%" border="0" align="right"> <tr> <td class="codebox" id="ContentPane" runat="server" valign="top" align="center">< FONT>td> < FONT> > < FONT>
aggiedan97
| 30 Jun 2008 10:12 PM |
Not sure what happened with the text editor above... However, I applied the ... around the HTML text and it applied as expected. While I am most grateful, I would appreciate knowing how to apply this to a skin. Thanks again for your input. |
| 30 Jun 2008 10:56 PM |
The < and > were interpreted as tag delimiters. When you post code, make sure that both of those characters are surrounded by white space. If you've done the css correctly and your content page has the right class, the code should work. |
aggiedan97
| 30 Jun 2008 11:00 PM |
Actually, the last two > > are not actually show that way..they are a product of attempting to edit my post in this forum.
this is the html snippet
"<table cellpadding="3" cellspacing="0" width="60%" border="0" align="right">
<tr><td class="codebox" id="ContentPane" runat="server" valign="top" align="left">td>
tr>
table> " |
aggiedan97
| 30 Jun 2008 11:01 PM |
nevermind, I can't seem to paste html in this editor without it accepting it as HTML text....~ |
aggiedan97
| 30 Jun 2008 11:06 PM |
try this again.. < table cellpadding="3" cellspacing="0" width="60%" border="0" align="right" > < tr > < td class="codebox" id="ContentPane" runat="server" valign="top" align="left" >< /td > < /tr > < /table > |
aggiedan97
| 01 Jul 2008 6:26 AM |
Attached is the skin I am attempting to create the scrolling window within.
I was able to accomplish it by adding he ... within the HTML/text module.
In the attached skin I have attempted to add it to the content pane. |
Attachment: 171263119971.zip
| 01 Jul 2008 7:02 AM |
ok, it works if we do this:
/*Code for scrolling HTML/text box*/ .codebox .Normal { padding: 3px; margin: 3px; overflow: auto; height: 150px; }
The problem is that DNN adds the Normal class to the text in each container, so we have specified that for any text that uses the Normal class inside the codebox class scroll the text
aggiedan97
| 01 Jul 2008 10:33 PM |
Well - I have good news and bad news...
Bad News - I updated ".codebox .Normal" and it didn't work.
Good News - based on something you stated about the .Normal evaluation made me think to move it after the actual .Normal evaluation in the css file. As I understand it, this will cause it to be evaluated after the .Normal and therefore it is evaluated and not overriden.
Again, thanks a bunch and I appreciate everything. |
| You are not authorized to post a reply. |
| RE: Keep Testing Skins by ollep | | Some details re Logo possition:
HTML:div class="header">p>[LOGO]p>div>Found possitioning in "index_... | | Pathing issues after setting up a domain name by harlowj | | I had a site configured here: http://www.autorotate.com/portal/chl (all works good)I then decided to... | | RE: Keep Testing Skins by ollep | | Hi Lee – and Joe
I’m Using DNN 4.5.5
I just installed Summer Breeze Skin and Template, and a... | | RE: DNN - web services not working by jncraig | | Do your web services have their own config files? Are they located in actual directories below the ... | | RE: Installation on Vista by jncraig | | You install Visual Studio according to the installation instructions. Once installed, you can "open... | | Installation on Vista by jesp17 | | I followed the how to install DNN to Vista, but what I miss is the intallation of visual studio. Can... | | RE: Building a website with DNN by freedom22 | | Hi Lee, Thanks for getting back to me. I understand now what you are saying, but I am still confuse... | | RE: How to limit access to the admin menu.... by tallorder | | Hi Lee Unfortunately I can't see how it works in reverse because the original process involved movi... | | RE: Building a website with DNN by leesykes | | Hello,Those classes refer to the menu, and therefore will not be specified in your skin.htm file as ... | | RE: [HOUSEMENU] token not working by leesykes | | Glad you sorted it, thanks, | | RE: [HOUSEMENU] token not working by whred5 | | OK I fixed myself after googling the problem. If anyone else comes across this situation you need t... | | DNN - web services not working by paulrobinson | | Good Afternoon,Please help. I have just installed my DNN web site to my dedicated live host machine... | | [HOUSEMENU] token not working by whred5 | | HiI have been playing around with the Lazy_Days skin in an effort to learn css based skinning, I hav... | | RE: Building a website with DNN by freedom22 | | Lee or Joe, I meant that the skin.css file I downloaded has classes like .main_dnnmenu_item td w... | | RE: Building a website with DNN by freedom22 | | Lee, thanks for your reply. I did find the files. I am going through your tutorail, and in video7... | | RE: page publish date by leesykes | | I would suggest you view these tutorials:User Accounts new features User Accounts and User Settings ... | | RE: page publish date by jncraig | | I'm not quite sure that I understand you, but ... on the user accounts page there are these options:... | | RE: Best so far for me by jncraig | | I like the Snapsis CSS Nav Menu. You'll find it at Snapsis.com. | | RE: How to limit access to the admin menu.... by leesykes | | Hello,Simply reverse the process, you can copy the settings from one of the other admin menu items t... | | RE: How to limit access to the admin menu.... by tallorder | | Shame about the parent page drop down being grey out since any Site Administrator is going to want t... |
