Subject: 4.5.1 Red Leaf Skin 1.3 - House Menu 1.4 Error
DLSTaylor
17 May 2007 7:21 AM
4.5.1 fresh install
Issue 20 Red Leaf Skin
House of Nuke Latest V1.4 HouseMenu
Local Host
When I add House Menu Module to page and click Settings from the Module dropdown the following error occurs. Also the Page settings does not show House Menu Options.
Have tried uninstalling and reinstalling skins and house menu but error does not go away.
Error: Module is currently unavailable.
DotNetNuke.Services.Exceptions.ModuleLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetNuke.Services.Exceptions.Exceptions.ProcessModuleLoadException(PortalModuleBase ctrlModule, Exception exc) at TimRolands.DNN.Modules.HouseMenu.HouseMenuOptions.LoadSettings() at DotNetNuke.Modules.Admin.Modules.ModuleSettingsPage.Page_Load(Object sender, EventArgs e) --- End of inner exception stack trace ---
21 May 2007 2:52 AM
For the RedLeaf skin you need to install the house menu skin object not the house menu module, thanks,
21 May 2007 2:53 AM
PS. - After installing the HouseMenu skin object you will now need to uninstall the red leaf skin and then reinstall it.  This is so that the skin can pick up the house menu.
Forums > Users Lounge > Everything Else > 4.5.1 Red Leaf Skin 1.3 - House Menu 1.4 Error
