Subject: DNN Source Code modification
Mark Schuler
11 May 2007 11:03 AM
I want to modify IFrame so it only takes the first summary part of a government page I'm trying to display.  (The IFrame no scroll property doesn't work).
I downloaded/installed the source but I have two problems.
1.  From Windows Explorer I can see the DesktopModules folder, and an IFrame sub-folder that has IFrame.ascx (I installed the module from admin), but not IFrame.ascx.vb.   Where's the VB file?
2.  When I open the solution in Visual Studio 2005, the Solution Explorer doesn't show the DesktopModules folder (it shows every other folder: admin; App_Browser; App_Code;...  )
Thank you for the help.  I read the tutorial on modifying the Blog module, but it didn't answer these questions.
Mark
Forums > Users Lounge > Everything Else > DNN Source Code modification
RE: OWS Query Template Results by VickySwift
Hi, In the end I achieved what I needed with IIF statments and ALTERNATE Pretty sure its not the...
RE: Login problem with other browsers than IE by kana
I added alert(); into onkeypress and now after I press enter on messagebox page is forwarding fine. ...
RE: OWS Query Template Results by kana
I don't know, that is possible, but I would try to use javascript in dteial template to build string...
RE: How to change primary domain? by aventhika
Hi it is an easy ,for that change visit here ,i am using this site only for my change.All the Best...
RE: Link to PayPal Unsuccessful by jorge569
Same problem here....please post answer
daisy chain continuous loop of all the flash files by mlorence
I have an install of dnn 05.02.02. I had a flash guy make a movie for my home page. There are 6 file...
Furniture Store Web 2.0 DNN Skin by coding-staff
Coding Staff is proud to announce a release of DNN Skins and Furniture Store Web 2.0 DNN Skin Ne...
301 Redirect on GoDaddy by kayt61
Hello,I have been looking for a simple set of instructions on how to make a 301 redirect from www.my...
Hello, I have three pages in DNN - Login, Main and Advanced. Login contains only OWS module for ...
RE: Request a Tutorial:Forms and SQL by leesykes
That's great, thanks for adding this in Dave
RE: Request a Tutorial:Forms and SQL by dhassall
I have added a new forum entry which I hope will help others http://www.dnncreative.com/Forum/tab...
DataSprings DynamicForms Form Completion Dynamic SQL by dhassall
I trawled around trying to find out why my SQL Insert was not working. After some trial and error...
RE: HTML module not updating after transfer from localhost to live server by chrisoc
Hey guys,Thanks for the replies.   All seems to be working fine now.  I had previously cleared the b...
RE: w2k8 r2 - dnn site visible locally but not from internet by guyperrin
thanx joe. i just kept slugging away at this one. finally, when i gave IIS_IUSRS Full Control, i w...
RE: HTML module not updating after transfer from localhost to live server by jncraig
Check to make sure that you adjusted your portalalias table to point to the live site. It's possibl...
RE: w2k8 r2 - dnn site visible locally but not from internet by jncraig
Check to make sure that DNS points the site's URL to the web directory.  Your host ought to be able ...
RE: user retrieve password by giving email by jncraig
That should work. As with most things like this, I would recommend that you test and verify this ...
RE: Creating a new user by jncraig
DotNetNuke uses the ASP.NET membership scheme. I haven't tested, but I am reasonably surethat the s...
RE: Email Verification by jncraig
Is this a question about Dynamic Forms? You can use Regular Expression validation to force the us...
RE: Issue 33 SQL updating page settings by jncraig
Can you describe the problem a bit more?
