Subject: Ad Sense
ORP
19 Apr 2007 6:07 PM
Thanks for your mail response Lee.
It’s slow sometimes – but eventually I get it right – I think?
The Red Leaf skin is CSS based, while the Vortex one is Table based?
Consequently I need to put in table rows for Google code and the classes I need to add. As opposed to the DIV tags you are using in the CSS skin?
(Google now say it can take several day to have the AdSense account, so maybe I should do the CSS-Skinning-Tutorial while I wait.)
Cheers
Olle….
Hi Olle,
They are just names for the skins, you can give your skin any name you wish,
Hi Lee
I’m waiting………….._
In the meantime I checked the tutorial, and you have “Index.html” and “Transparent.htm” files in the red Leaf skin.
What does those files corresponds to in the Vortex Skin we created?
Do I need to create these files?
Cheers
Olle….
20 Apr 2007 7:50 AM
Hi Olle,
Yes the red leaf skin is CSS based and the vortex one is table based.  However you will be able to take the CSS containers from the red leaf skin and place them within a table based skin and they should work fine. So that part of the Adsense tutorial should work in a table based skin.
Hope this helps, have fun
Cheers,
