Subject: I need to change primary path
markp
17 Apr 2007 3:08 PM
When a script installation, installed my DNN it put the primary path to portal 0 at chickensplus.info/DNn.  I need to change that to chickensplus.info.
I know I will have to go "behind the scenes" to do this but can anyone tell me all the places I would have to edit.  I am also assuming their are some tables I would have to change manually.
I have my install working , but right now if you try to restart the program from the host menu, you get a permissions error.  I think its becusase its looking for webconfig in the DNN folder, and its not there anymore, Its on the root (
Thank you
Forums > Users Lounge > Everything Else > I need to change primary path
RE: PowerDNN by jazzylily
RE: PowerDNN by DavidWSnow
RE: PowerDNN by mgordon
Great!
RE: PowerDNN by MobileNow
