Subject: Looking for DNN developers as freelancers
Davidgu
17 Apr 2007 10:18 AM
I'm not sure it is the right place for it and if not - please, let me know if know more appropriate place to publish it.
Our company develops Internet portals based on DotNetNuke.
We are looking for a freelancer with experience in .NET (2-3 years) and with experience in creating DNN modules.
We are looking for a long term relationship as we have many projects.
David Guterzon
david@target.co.il
Forums > Users Lounge > Everything Else > Looking for DNN developers as freelancers
