Subject: moving a DNN site to another server
dnnuknewbie
27 Mar 2007 11:01 AM
Greetings.
I have a DNN site (3.3.4) that i want to move to a backup server. Then i want to upgrade it to 4.4.1. We have to wipe the production server (memory all in the wrong places) so once done, place new updated site back to server.
I am a novice with all of this.
Here are the steps i am thinking of taking. Please let me know your thoughts on whether this is the right approach.
Do i simply drag over the portal folder. Copy the database. Alter the web.config and bingo, it all lights up!!
Or will it be easier to use a backup/restore program. If so, any suggestions to what works best.
Thank you. Regards. H
10 Apr 2007 6:02 AM
Yes copying across the DotNetNuke installation files and the database should work. Just make sure that you create a backup of everything before attempting it. You may also want to checkout this forum post:
How to copy a live site to a localhost installation.
Forums > Users Lounge > Everything Else > moving a DNN site to another server
