Subject: Timezone issue
markdurham
21 Mar 2007 3:16 PM
Hello Everyone,
Im a bit of a novice on DNN and need some advice.
I have a DNN site - www.atlantis449.co.uk which is hosted in canada.
I have installed a english UK pack and this is enabled in host / admin and it has changed all the date formats to Uk format - great but ...
The timezone functionality in admin does not work.
All my timestamps are in canada time from my server rather than the timezone which i have set for the portal.
I have tried everything to fix this but no luck.
Can anyone advise / help on what i should do so all my timestamps in discussion modules and when someone registers etc is in UK time.
Mark
eureka
22 Mar 2007 12:38 AM
Hello Mark
If you navigate to Admin> Site Settings> scroll down the page locate and expand "Other Settings" . There you can then set your portal timezone to (UTC 00:00) Dublin, Edinburgh, Lisbon. Then scoll further down the page and click "Update".
Hope that helps
Lynn
