Subject: Breadcrumb quirk... or not?
daveg955
20 Mar 2007 7:10 PM
Pardon me if I'm not using the proper terminology but I think you'll understand what I mean.
I have a set of pages in the menu bar.  Each of these is a 'parent' page.  The names of these pages do not appear in the breadcrumbs but the child pages do... however, it does not show the path
For example, There is an "Events" parent page with an "Ongoing Events" child page.  When clicking the "Events" page, the breadcrumb only shows .: :. but when I click the child page it shows .ngoing Events:. without referencing the parent page.
I'm using a simple skin that I constructed after watching your videos.  It's based on the DNN blue horizontal fixed width skin.  I use VWD to tweak it.  There is no XML file associated with.
Except for the breadcrumbs, I'm not having any difficulties.
Thanks.
21 Mar 2007 4:04 AM
Your breadcrumbs need to be told which menu level they should start from, in your skin.xml file add:
(Object)
        (Token>[BREADCRUMB](/Token>
        (Settings>
            (Setting>
                (Name>Separator
                (Value> >
            (/Setting>
            (Setting>
                (Name>CssClass
                (Value>Breadcrumbs
            (/Setting>
            (Setting>
                (Name>RootLevel
                (Value>0
            (/Setting>
        (/Settings>
    (/Object>
Or if you are using an .ascx file use:
< dnn:BREADCRUMB runat="server" id="dnnBREADCRUMB" Separator=" > " CssClass="Breadcrumbs" RootLevel="0" / >
(NOTE: I've added spaces and brackets instead of < into the tags so that it shows in the forum)
daveg955
21 Mar 2007 1:20 PM
Many thanks, Lee.
I don't know where that errant smiley came from although it was approriate for my state of mind at the time.
Forums > Users Lounge > Everything Else > Breadcrumb quirk... or not?
