Subject: Hosting company to bewareof WebHostForASP.NET
markp
17 Mar 2007 11:10 PM
InternetSupervision Alert
03/16/2007 21:03:27 (GMT-06:00)
URL:       http://www.peacemerchant.info
Status:    FAILED 4 times since 03/16/2007 21:03:27
Reason:    Timeout
03/15/2007 23:43:41 (GMT-06:00)
Status:    FAILED 4 times since 03/15/2007 23:43:39
Reason:    Timeout
I have had nothing but problems. I even offered to PAY for them to delete all the files and to reload DNN using the latest verison.  All I get from them is that everything looks fine to them.  Not only does the site suffer from load times that make it unusable, I cant even load a module.  I dont get an error, it justs dosent appear in the container.  Now tomorrow it might, then the next day it wont.
I found this company via an advertisment on www.dotnetnuke.com, I paid a year in advance  so I am stuck, wanted to warn others.
WebHostForASP.NET
markp
18 Mar 2007 7:50 PM
After this post , and one more like it, the company refunded my money tonight. The shame of it is , as many of us know, if not installed properly DNN can exhibit weird behavior. I still believe if they had done what I asked and reinstalled DNN , my main issues would have disappeared.
Forums > Users Lounge > Everything Else > Hosting company to bewareof WebHostForASP.NET
