Subject: declare hacks
eureka
11 Mar 2007 5:06 AM
Hi Lee
In your RedLeaf skin that you have included  a Javascript to call a IE hack.
I need to add both IE 7 hacks and IE hack links to a skin.  What do I need to edit to include IE 7 with the IE ?
Lynn
eureka
11 Mar 2007 5:23 AM
Oops! the hack enclosed css external links code didn't show up, even though I put it in Dreamweaver first.
The  code should be within html tags <>  but I will remove and replace with () to see if it shows up this time.
(!--[if lte IE 7] )
(link rel="stylesheet" media="all" type="text/css" href=" IE7.css file" /)
  ( ![endif]-- )
 (!--[if IE] )
(link rel="stylesheet" media="all" type="text/css" href=" IE.css file" /)
(![endif]--)
Lynn
