Subject: default.css
MWiseman
19 Feb 2007 1:10 AM
The default CSS contains styles for the wizard and file manager etc. Can they be trimmed out. What happens if you dont have styles specified for these do they fall back to the browser default.
Just trying to cut down loading times for pages.
Mark
19 Feb 2007 5:31 AM
Hi Mark,
Yes you can trim down the default.css quite a lot. - Have you had a look at this tutorial?
Reducing the DotNetNuke CSS file sizes
MWiseman
19 Feb 2007 9:33 PM
Thanks Lee,  I am going to take a deep breath and give it a go.
Mark
