Subject: Problems with DNN 4.35 install on seekdotnet, run time errors from the admin menu
Dano W
25 Jan 2007 8:55 AM
I'm using seekdotnet as a hosting provider, whom generally I'm finding very helpfull and a good host, however I have the following problem that seems to be stumping them at the moment.
1st time I installed DNN 4.35 all was fine.  I then went and amended the Profile.ascx  file to reflect some changes I had made to the registration page.
After this, once I logged in as either host or admin, everytime I went to select an option from the 'admin' menu'  I would get the below run time error which I have copied below.
Since this both myself and seekdotnet have reinstalled DNN, but get the same problem.
Has anyone come across this before, any help in solving it, and you will be known as a legend!
Cheers
Dan
Error message is-----
Server Error in '/admin' Application. -------------------------------------------------------------------------------- Configuration Error Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately. Parser Error Message:
 The code subdirectory '/admin/App_Code/Reports/' does not exist. Source Error: Line 80: Line 81: Line 82: Line 83: Line 84: Source File: D:\Clients\C3526\udoido.com\public_html\web.config Line: 82 -------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.210
eureka
25 Jan 2007 10:30 AM
Hello Dan
I understand that DNN 4.3.5 has several bugs, some of which are related to page creation and using "default template", some bugs are connected to the dropdown menu on the containers. DNN 4.4.0 has solved some of them.
I have had similar problems with my site. I intend to upgrade to 4.4.1 as soon as possible.
Lynn
Dano W
25 Jan 2007 10:37 AM
Thanks Lynn
I guess upgrading the DNN version is upto the host provider though as its installed through their control panel.
The weird thing is, that it worked the first time around.....
The only thing I can think of is, to replace the old version I deleted the Mysql database, then reinstalled DNN over the top.  Maybe its not a completly clean install that way....?...
Dan
lisabarley
03 Feb 2008 8:39 PM
I am with {url=http://www.SeekDotNet.com] SeekDotNet.com [/url] as well and regarding your DNN problems, usually it is about the bug in their control panel (this is a minor problem and their support usually will trouble shoot the case for you.)
I did have the same problems and I just ask them to manually install the DNN for me. The error went off and I am happy...
Forums > Users Lounge > Everything Else > Problems with DNN 4.35 install on seekdotnet, run time errors from the admin menu
