Subject: User Account Management
lisawalts
30 Dec 2006 6:47 PM
Hi Lee. I am on the latest version of DNN 3.xxxx. The user account module functionality is so confusing for a user. Is there a way to get rid of the "visibility" data in profile properties and to hide the "Manage Services" all together? Or to get everything on one page? I got the registration page to work like that but don't know how to do it when a user wants to manage their account.
Lisa
02 Jan 2007 7:29 AM
Go to: Admin / User Accounts
Click on the User Settings link
You have a couple of options:
Default Profile Visibility Mode: if you set this to admin, only admin will be able to view the options
OR
Display Profile Visibility: Untick this to completely remove the display of them.
lisawalts
02 Jan 2007 8:06 AM
Lee - thanks for your response. Unfortunately, I don't see either of those options. Is is because I'm using DNN 3 instead of 4?
Lisa
02 Jan 2007 8:12 AM
You can see the details of this here:
User Settings (part 2) in DotNetNuke 4.3 and 3.3
(1 video – 4min)
They added those options when they released version 4.3.5, so if you upgrade to 3.3.7 you will be able to access those options, thanks,
Forums > Users Lounge > Everything Else > User Account Management
