Subject: Add new portal
acda150
13 Nov 2006 5:32 AM
Hi evryone,
My machine ip address is 192.168.2.222
The name of my default directory is dnnroot.
I can browse my portal remotely by typing http://192.168.2.222/dnnroot/default.aspx
I want to add more portals using potals option under Host option. Could you please explain me how to add more potals ? pls give me an step by step example.
ash
14 Nov 2006 4:03 AM
When adding a portal, you have 2 options:
Child - which will be: www.example.com/childname
or Parent - www.a_new_domain_name.com
So, log in as Host
Go to Host menu / portals
Click "Add new portal"
Select parent or child - we will select child in this example
to the end of the portal alias name add the name of your child portal eg.
localhost/DNN435_Tutorials/test_child
enter title etc.
Template select DotNetNuke to load up the standard view when you first install
Security Settings, add details
Click on create portal
That's all there is to it.
If you create a parent portal, you will need to point the parent domain name to your DNN installation in order for DotNetNuke to pick it up.
acda150
15 Nov 2006 6:48 PM
Thanks lee
